russellle
- Jul 1, 2012
- 12
- 0
- 1999
- 5.9 Magnum
I have been looking and not found much on this. There is plenty about upgrading from 1/2 ton to 3/4 ton and 1 ton axles from the same generation of trucks. I have a 99 1500 with 9.25 rear axle. I was trying to replace the pinion oil seal and wound up over torquing the pinion nut, causing the crush sleeve to do it's job. After starting to take the rear end apart, I found something I am not sure about. It appears to me that a part of the differential has been riding against the bearing cap and wearing a groove into it. See pics. One shows the protruding metal piece which is loose but will not come out. The other two show the two bearing caps, one with an apparent groove worn into it and the other from the other bearing.
That being said, I am not sure this rear end is worth rebuilding (at least not to me). I was able to buy a 2003 9.25 axle for $300. It has the same gear ratio 3.55 and LSD. It does have disc brakes, which I was planning to convert to in the future anyway.
All that being said, does anyone know of any issues with this installation? I know the yoke on the pinion is different, but I have another drive shaft with the correct connection. I have 16 inch rims with 315/75R16's mounted. Do I need to mess with a proportioning valve at all? I am
