Gladiator rear springs
DA67Goatman
Ohio USA
The Gladiator uses basically the same rear suspension therefore, the springs were a easy swap. They ride so much nicer being a lot softer rate. I matched them to the KYB Gas-A-Just shocks. It's as close as I have come to getting the the feel of the 4 Corner Air suspension with traditional coils. Having the Airlift Ultimate 5000 allows me to stiffen up to counter any amount of load.
hdoggie24
Huntington Beach CA
Interesting. Are these for stock height or do these actually lower our ram trucks?
DILLIGAF
Canada
Clayton off-road Gladiator 4 link and panhard bar also fit ;)
DA67Goatman
DA67Goatman
Ohio USA
The springs themselves are the same height uncompressed, I did a side by side after getting one side swapped. I forgot to take measurements, but to the eye, they are maybe an inch shorter installed but that could just be the softer rate compressing more to hold the same weight. Meaning if you have a bunch of junk back there they would compress more equating to a lower stance.
