Got my lift on! 4 inch zone and Bilstein 6112s set at 2 inches
FLYxxBOY
FLYxxBOY
Ohio
Beautiful ride! How tough was that flag decal to install? I have been on the fence on that exact one for a while, and keep telling myself getting it on straight with no bubbles must be impossible. After seeing yours, I think I have to have one.
I paid my local window tint shop 20 bucks to do it lol. I know myself and it would more than likely end up as a ball of trash on the ground haha. They used a spray bottle with soapy water to help
joeygster
Ancaster, Ontario
Looks great brother. That's why I love this forum....you don't really need to experiment because someone will in all likelihood have the set-up you want and will be just dying to fill you in on the specs.
ilovemyramlaremie
Moravia NY
Looks great!! And perfect stance.
For some reason this 4 inch lift set up , looks like most 6 inch lifts. I’ve been tossing the idea between the 4 inch, and 6 inch lift, now I’m thinking I should go with the 4 inch, I have 34 in tires.
Mopar1987
Livingston TX
Did you do any before measurements? And I’m asking for my own knowledge. In my mind everything is level, upper control arm and cv axle with the 4 inch lift. And if you throw the 2 inch lift with the bilsteins, wouldn’t the arms and axles by slightly down? I may be wrong. I’m just trying to plan out a lift and your truck looks amazing.
FLYxxBOY
FLYxxBOY
Ohio
It's because it is basically a 6. 4 inch but with the bilsteins adjusted to 2 inches adds additional lift.
FLYxxBOY
FLYxxBOY
Ohio
If i remember it was about 38.5 or 39, and now the front sits around 44.5. When I was planning it out and looking at other rides with the same setup the angles varried as well since different trucks tend to sit and settle differently. If I remember right too, the top spacer on the zone lift is angled so that might help the arms sit like they should as well, even with the additional preload with the bilsteins
Freed127
Tamaqua PA
@FLYxxBOY have you noticed any settling with the 6112? I have a zone 6” with 5” rear coils and 5100s at 2.1 and will be swapping to the 6112 shortly. Debating where I would like to set them. It’s looking like it will be 2.6 with how perfect yours sits!
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Thanks for everyone that gave me advise and helped me out, especially JB1 and Nick from gotexhaust. As I said it's the Zone 4 inch lift with the 3 inch coil options for the rear plus 1 inch rear spacer. Bilstein 6112s up front set at notch 6 (about 2 inches) with the Zone upper control arms. The CV angles are almost flat and the balljoint angles are great. The wheels are Motiv Magnus 20x10 -25 offset, wrapped in Cooper Discoverer STT pros 35x12.5. Front height to middle of wheel well is 44.5 inches both sides, and 45 both sides in the rear which was perfect since I wanted a smidge of rake.
View attachment 199816 View attachment 199817 View attachment 199818 View attachment 199819 View attachment 199820 View attachment 199821 View attachment 199822 View attachment 199823 View attachment 199824 View attachment 199825
That's a nice looking front lift!! Looks good and fully functional!
What are the plans on the rear axle? I see some red lower link bars there.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Excellent setup as well. Digging the offroad bumper and head light upgrade.
FLYxxBOY
FLYxxBOY
Ohio
Damn nice truck! What size tires you running? And not much at all, maybe a quarter inch I'd say. It's always fluctuating with fuel and I can't remember what the fuel level was when I did my initial measurement. They are much beefier than stock you will love em
FLYxxBOY
FLYxxBOY
Ohio
I've got that all done, powdercoated the hellwig swaybar, got cores panhard bar and upper and lower control arms. Swapping the hellwig endlinks for zones since I like greasable stuff 20201009_180143.jpg
FLYxxBOY
FLYxxBOY
Ohio
@FLYxxBOY I’m running 37x13.50s. There is also a Zone 1.5 body lift hiding in there as well haha
Love it, looks like a monster. And that makes sense, it looks taller/beefier than mine for sure. I debated doing a gear swap to run 37s (only have 3.21s now and it hunts enough with the 35s) but in all likelihood I'll step-up to a 2500 in a couple years anyway. Just wanted something fun to drive around now
Freed127
Tamaqua PA
@FLYxxBOY i know the feeling, that’s why I have both. Paid my 1500 off and got a 2500 now to drive as a daily.
Your truck a 6 or 8 speed? I have 3.92s with a 6 and it does search for gears sometimes. However headers and a tune helped immensely for turning the big rubbers
RedSRT4Me
Scottsdale, Az
2015 CC Sport
I've got that all done, powdercoated the hellwig swaybar, got cores panhard bar and upper and lower control arms. Swapping the hellwig endlinks for zones since I like greasable stuff View attachment 234500
Any tips on that driveshaft blackout? That's about the only thing I haven't touched.
My setup needs some love. Clean up, unbolt, grease and retorque. Half days worth of work.
37x12.5r20 Nitto Ridge Grappler
4.56 yukon rear gear.
8 speed tranny
FLYxxBOY
FLYxxBOY
Ohio
@Freed127 it's an 8. I'm tuned by Jay and have some headers from arh on the way so who knows maybe I will do 37s eventually, I'm never satisfied lol. The 2500 looks sharp!
@RedSRT4Me damn truck looks good! I think this is a sign I need to do a regear and 37s eventually lol. And once a year I go all over the underbody, wash and dry it really well, wire brush off any rust I find, and then paint it with rustoleum flat black paint. You can quickly wipe off if you overspray, but it keeps things looking great. This past October I didn't find any new rust (I live in Ohio where we get salty roads) so it definitely helps. This pic was right after it was painted, and it holds up through the weather and playing around in the woods great
Lowrider357
