Grinding Noise Upon Start-Up
97RamBaby
California
5.9 Magnum
Hello,
Was hoping to see if anyone has experienced this or heard of this issue before. I have a 1997 Ram 1500 5.9L with under 50k miles which I bought about a year back. It stayed in a garage for a few years before I bought it and decided to change out all the oils. A few months ago though, I started hearing some interesting noise coming from the bottom of my truck.
It doesn't always happen, but when it does it sounds like a grinding noise from the bottom of the truck cabin(?) Like around the transmission area. I haven't had any performance issues though, just that this noise kind of worries me. It will sometimes happen on a cold start in the morning when I am backing out in reverse. If I let the truck idle for a few minutes though, the grinding sound doesn't happen. Also, though a slightly different in noise in this scenario, another grinding noise seems to happen every so often when I am slowing down or coming to a stop downhill when applying brakes. Not sure if these two sounds are related, but since they seem to come from the same area and sound somewhat similar, I think they are related or is the exact same problem.
Any help or pointers would be appreciated. Thanks!
Vendridi
Sacramento
Most likely the fly wheel not engaging correctly. Had this issue awhile ago in my 89
97RamBaby
97RamBaby
California
5.9 Magnum
Interesting, would have never thought it was the flywheel. Was it an expensive fix for you?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If the truck was older & had more miles.
I would be checking the Starters teeth & flywheel
Is it an automatic transmission ?
GTyankee
3.0 ecodiesel
I asked about the type of transmission, because Stick Shifts have a Throw Out Bearing, that when it wears out, makes quite a bit of noise
