Harbor Freight Polisher
dhows31
Mississippi
Is the HF polisher any good for those who have it? I'm new to polishing and would like to learn. Thanks in advance.
BeanRAM
Wisconsin
It is a great polisher to start out, I still have mine from years back and will use it from time to time. Their pads even work decent although I don't use them anymore.
bhonshell37
Washington
Gary Dean uses a HF da polisher. HF is in most cities so you do not have to order. The HF polisher is a good beginners tool. A polisher about the same size is the PC7424XP of which I have. Go buy one and order some quality pads from Autopia and Autogeek. Both are having St. Patrick day sales
Sent from my SM-N910V using Tapatalk
Grant211
I have this one from harbor freight and it's really good. Just be careful as it spins really fast and you can burn the paint..
dhows31
dhows31
Mississippi
I think that's the one they have on sale for $50 I mean I can't see spending $250 on a polisher when I don't even know if I'll be able to do it.
dhows31
dhows31
Mississippi
Thanks for the replies guys. I figured it couldn't be that bad. I was gonna use meguires compounds.
bhonshell37
Washington
20170317_081113.jpgHere are 4 of products Meguiars sells
THETANK
up jor *** mang
2015 R/T
if it is dual action how can it hurt a paint job, mine spins up to 6000 rpm and zero issues, oh not HF
Grant211
its the lack of knowledge using the buffer...its when people start tilting the buffer at an extreme angle or working on one area just to "get that little spot". You will overheat the paint and burn through.
BeanRAM
Wisconsin
Meguiars m105 and m205 or the ultimate compound and ultimate polish are going to be perfect for you.
Reactions: Kab
dhows31
dhows31
Mississippi
Yeah those are the ones I wasn't aware they had so many I thought they only sold a few. And I have some knowledge as to not keep it in one place too long and not to tilt or anything. I'm also gonna try it on my old 04 first
dhows31
dhows31
Mississippi
Which compounds do they sell at auto parts stores because that's probably what I'll get. Just for starters
BeanRAM
Wisconsin
While at harbor freight pick up some megs m105 and m205
Andrew09HEMI
Do you really need a compound? Usually you can get a lot done with a good quality polish. Any cutting compound will produce more swirls which are harder to remove. I use Chemical guys products cause they're affordable and produce great results while also being pretty forgiving.
bhonshell37
Washington
I have never had a cutting compound produce swirls. Foreign matter on a pad will instill swirls
dhows31
dhows31
Mississippi
I'll take a look and sorry I'm not too familiar with all the differences.
dhows31
dhows31
Mississippi
Okay so let's say I just want to get a good shine on my truck and maybe help some oxidation on family members vehicles, should I just use the cutting polish and the final polish
bhonshell37
Washington
I would try Meguiars Ultimate Compound first. Then move on to a more aggressive cut if the above does not work as you like
bhonshell37
Washington
As for shine, get Meguiars Gold Class liquid wax
