Jason Reese
Ok new to the RAM world. Here we go! Went to the store came out went to turn truck on and nothing except accessory power. Power locks, windows, radios, lights (interior and exterior) all work. Slight click when you try and turn it over the first time. I immediately went and bought a $200 battery (that was crazy) . Same issue!!! I have been doing some reading about the same issue. I have tried taking the negative side of the terminal off for hours to see if computers reset itself but no dice. I have gone to the fuse block in the engine compartment and made sure all relays and fuses were seated properly. Had it towed to the house. Tried to put it in neutral and turn it over that didn't work either. The put it back in park. NOW it wont go into drive reverse neutral or anything. So from what I'm reading it could be the (Wireless Control Module) or what people has been calling the WIM. Is there a way to bench test this before dropping $300 on this part and having to spend another $100 to get the key reprogrammed? All the forums I was looking at were from 2008-2011. Surely someone has figured this demon problem out by 2017. PLEASE HELP! Thanks guys!
