Hazard Warning Flasher
metalwolf69
Canastota, NY
Ummm here is it? Im trying every idea to get my turn signals to work. Ive already replaced the multi-switch and nothing. Umm any idea's
metalwolf69
metalwolf69
Canastota, NY
I didnt see anything like flashers in my fuse box. Just relay's and fuses.
metalwolf69
metalwolf69
Canastota, NY
Could a flasher be my problem? The turn signals and hazards work.. As long as the cab of my truck is ICE freaking COLD. I hope its not the wireing or something EXPENSIVE!
adamwilkes14
Well, when they are not working is the flasher getting hot? Maybe pull the flasher and look at the contacts and make sure they arent gummed up or corroded...
metalwolf69
metalwolf69
Canastota, NY
K, Ill do that tomorrow during my lunch break. its dark and snowing like hell ATM
adamwilkes14
Thats the only thing I can see making it do it...of the relay gets too hot and just fails to operate...kind of like a relay you know...they can get too hot and stick open on a fuel pump and make it run without the ignition switch activated...
metalwolf69
metalwolf69
Canastota, NY
But if the flashers are in the fuse box why would the temp. of the cab effect it?
ramthis9501
Oklahoma
5.2 V8
I wonder if there's a loose wire somewhere under the dash that fell onto the heater under there. If it did, then when you turn on your heater, maybe it melted the wire insulation and is shorting it out somewhere? Just a thought...
02Steve15
Connecticut
my friend had that problem with his accord and it was a blown fuse. they are really cheap to fix if that's the case..
lilfroger
5.9 CTD
I can't get the ground schematic to attach ... to big ... as usual smiley_emoticons_wallbash.gif
Send me a PM w/ your email address and I will deliver it directly to you.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I agree, I'm thinking ground. I don't know about 02, but 03 does not have flashers. It is totally controlled by the modules. The clicking noises which sound like the old flashers is a audio unit made to sound, you guessed it a flasher. FCM actually sends a signal to the turn signal relays and turns them on. And the audio unit inside the cab that sound like a flasher. Now of course I am speaking of our beloved 03's and I am clueless what the 02 does. Good luck...
Out of the 03 manual:
OPERATION
The instrument cluster monitors the multiplexed
multifunction switch operation. When the hazard
warning switch is activated, the instrument cluster
will send a J1850 bus message to the Front Control
Module (FCM), then activate the two turn signal indicators
and audible click in the instrument cluster.
The FCM will then activate the necessary relays in
the Power Distribution Center (PDC) to begin flashing
both the front and rear turn signal indicator
lamps.
Joey93
