Headers
ptuttle78
Any tips on installing header on drivers side
shane1981
millington tn
pull the tire and fender well . pull the dipstick ,you will have to bend it to weave it between the tubes use oem gaskets and use stage 8 bolts but they can rattle after some time and cause false knock or use a different bolt with a lock washer and check the lines that run up the frame right by the headers they may be very close or were you looking for other advise?
tuned by jay greene
P
ptuttle78
I'm having issues with exhaust being in way. Catalyst
shane1981
millington tn
shorties are a direct replacement but you will need a y- pipe for longtubes. what type of header are you installing?
tuned by jay greene
P
ptuttle78
Shorty. I'm guessing I'm gonna have to remove the cat back. Which I was hoping I could do without moving the exhaust
shane1981
millington tn
its a pain in the ass to get the exhaust back right but its part of it
tuned by jay greene
P
ptuttle78
That dipstick sure is in the way, ain't it [emoji24]
P
ptuttle78
Check engine light after installing headers?
shane1981
millington tn
if your not tuned for them yes. you can try spark plug non foulers on the sensors but that doesnt work sometimes
tuned by jay greene
tantore
texas
what year is your Ram i install mine on a 2012 5.7.litter had to pull back the y pipe with a pry bar to clear the engine good luck
P
ptuttle78
Mines 2013 5.7
It seems to be leaking from passenger side. That was the side I had hell reconnecting. I get back under there with a pry bar
P
ptuttle78
tuned by jay greene
I may look into getting a tuner next
shane1981
millington tn
keep in mind you will need a custom tune to turn off the CEL and actualy see the gain but it would be worth it.
tuned by jay greene
reyzapien88
