Heating
gibbypa
Cummins 6.7
Hey everyone.
I have a 2017 Ram 2500 BigHorn with the 6.7 Cummins.
When it started getting colder here in central Ohio, I found I had very little heat in the truck. Luke warm at best.
I bought the truck new in 2017 and have never changed the coolant. Currently have just over 87500 miles.
First thing I thought was, as does everyone, thermostat. So I drained the system, flushed it and ran a cleaner as well. Replaced the thermostat and replaced the coolant with the proper OAT coolant. No change.
I then read there could be bubbles in the system after a flush that could impede the flow, so I squeezed on the upper radiator hose and did get quite a few bubbles that came up, but still no change.
Next, I learned the cold air door and actuator could not be closing and opening properly. I checked this and was working just fine. This is found right behind the glove compartment.
Lastly, I learned (from reading and watching videos) it could be a plugged heater core. The more I read, the more I learned this is not too common on a vehicle of this year and miles. Usually occurs much later in its life and miles.
Anyway, I flushed and back flushed the heater core and this was it. The water coming out of the core was not dirty and didn't see any real obvious reason for this, but after I ensured there was no air and re-attached everything, plenty of heat in the truck now.
So, for anyone with this problem, don't forget about the heater core. It wasn't on the top of my list, but something to keep in mind.
Todd
jejb
NW Arkansas
Is your heat gauge/readout showing that the engine is fully warming up in the colder weather?
I remember some threads similar to this last winter. So you might try some searching. Not sure if the threads were in this forum or one of the other 4th gen forums.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Hey everyone.
Todd
I have had this problem with my 2016 6.4L. Heater core is less than $100 bucks but of coarse the labor is about $1,000. How hard was it to just flush the heater core? And how did you go about it? If I remember right, there was not much room to even get in there to remove the hoses. Not sure on the Cummins, but from what I have read, the factory didn't clean the 6.4 engine well after casting the block. This led to all of that casting sand to plug up the heater core. I flushed the whole system (with cleaner) as you did, & it made very little difference.
Administrator
You need to backwards flush the heater core, you won't be able to push whatever crude through the heat core.
TMyers
USMC 84' - 92'
north wilkesboro, nc
Cummins 6.7
I have fought this dog for 3 years. I tried everything until I flushed the heater core a couple years ago. I'm was pretty sure coolant got mixed during a water pump recall and gelled in the core. I had pretty good heat once I first did the flush but after a while, the temperature lessened.
Two weeks ago, I took the time to flush it again. I blew the core out both directions with the water hose and the air compressor several times. We had some CLR here so I dumped it in the hose and let it soak in the core for about 15 minutes as well. Don't know if the CLR helped but anything is better than tearing the dash out. I've got good heat again so I'm either just moving casting sand around inside the core or pushing out goo.
4xdad
Edmonton Alberta
2015 powerwagon
It’s apita to get at the hoses right at the firewall so I disconnected it the hard lines It was still apita then I took a couple of 1/2 inch copper pipe and put it in the end of the rubber hoses that feed the heater core I flushed it both ways. I used some clear hoses and drained it in to 2 buckets. Then I filled the hoses with clr and let it sit for about 15 minutes. I also changed out the thermostat again apita. But now I have good heat and the temperature seems to be in range and thermostat is working.
JustinRam1500
