Help adding led light stripe to OEM led bed light
nrarangeofficer
Gurnee Il.
Adding led light stripe to OEM led bed light won't shut off on a 2022 ram 2500 6.4
I connected the stripe light to the driver side OEM led light they will shut off when you exit the
and lock the doors and come on when you unlock when you start the engine they stay on shutting off at the head light switch don't work or the cab switch anyone know how to fix this.
gofishn
Iowa
hemi 5.7L, 345 cu in
Clean up teh information so it is understandble, what you did adn what it is now doing.
post in teh genral Discussion thread, so more people will find it, and do so, first thing in teh morning, when more peopel willsee it throughotu teh day.
top of my head, if I underrstans correctly, you hooked up a ligth strip to OEM lights and now, they will turn oFF exit and lcok the doors, Will turn ON when you unlock or start engine. OEM Light strip turns off but aftermarket ligth strip stays on.
Is that correct?
If so, then you have hooked wires up incorrectly. to a constant, key on, power source, not the correct, power source which is light desired, on off source..
