Help with tail light replacement
B Vig
Hawaii
Hemi 6.1
Hi all - Having a problem finding the correct passenger-side tail-light assembly to replace the broken original for my 2015 1500 Laramie. When I look for parts, they show different connectors than the light assembly I pulled out. Photo is of the one I pulled, link is to mopar. I ordered a cheap one off of amazon that also does not fit. Any idea how I can find the right light assembly? Thanks.
ToxicFire
CA
You either ha e a normal tail light or the oem led tail.light.
aszumilo
Las Vegas
Should be a part number stamped on it somewhere. You could always search for one by that number.
Administrator
Your truck has the factory LED taillights and being a Laramie trim it should have the chrome edge. There's two versions of the LED taillights, the other doesn't have the chrome edge and was commonly found on the Sport trim level trucks.
The taillight you linked is the stand halogen taillight that cam on trucks with the Quad headlights.
Cableman
Longisland
I would just look on amazon for a set of new tails made for factory led trucks, a lot of them on amazon are made by spyder auto, should run ya around 200-250 and you can get a different look.
