HELP! Extended front brake line 08 Ram
Brandon F Porche
Louisiana
2008 Dodge Ram 1500 4x4 6-Ich Lift
Hello team,
I need help finding a front passenger replacement brake line for an 08 1500 5.7 4x4 crew cab with a 6-inch lift. The existing lines are approx 21 inches long. I can't find them anywhere and I've been calling and looking everywhere. Please someone lead me in the right direction and thank you very much for your time.
Administrator
DA67Goatman
Ohio USA
Stainless everything, buy these and never need another replacment, ever. reasonably priced and they are top notch customer service. Only catch is you can't just click a button and have them sent, you have to do the leg work to measure everything and order it accordingly. But this gives the freedom to alter and adjust as you see fit.
DA67Goatman
Ohio USA
Just so you are aware, they use traditional steel crimps and fittings so corrosion can still ruin those lines. I ran into thaat problem with a set from Russel as well.
B
Brandon F Porche
Louisiana
Thank you, I'm still in awe that I was able to find them on Walmart.com.. procomp part #7525
