nussdawg395
OK so here's the story, everything's great and all of a sudden ding ding and lamp out. The overhead display says passenger front turn signal out. This only occurs when the headlights are on. I figured that's because the filament changes from turn to parking light when the lights are on. So continuing it dings on bumpy conditions sometimes for a split second sometimes for up to 30 seconds. During this time if I activate the turn signal the indicator on the dash flashes very fast like a bulb is out but if the lamp out goes off it returns to normal.
To add to this mystery every once in a while I get in my truck and start it up and it dings and lamp out flashes and says that my passenger high beam low beam and turn signals are out and I have to turn on my lights flash my brights and hit the turn signal and it all resets.
So far I have changed the turn bulb and pulled the plug up by the firewall that all these connections run to and cleaned with some contact cleaner even though they looked nice and clean and corrosion free.
The only thing I've read that I haven't tried and may need some guidance with is to check the fcm for corrosion?!?!
I may be way off but I hope you guys can help with this. If needed I can take a video of the annoyingness of this situation
