Help me
Newbiee
3.6L
Hi, I have a 2013 Ram 1500 ST 3.6L. I am getting new rims and tires and I was wondering if I can switch my 17inch rims for 20inch rims. Will it fit? Will I need spacers or a lift kit? Any drawbacks? Any information is appreciated!
R.L.K.
Bristol , Tn.
They will fit fine , the Outside diameter of your tire & the overall width of the tire should stay close to the same .
Your factory 17 " wheels are (I beieve) 8" wide and have a + 25 mm offset
If you keep the hight &width the same on the tire , you should have zero issues with a 20X8 or 20X9 wheel with a 0mm to a + 19mm offset .
Hopefully more will comment on this below!
Sent from my SM-G900V using Tapatalk
