Hemi Stall
ktm1217
White Mills, PA
5.2L 318ci Magnum
My dad has an 04 Dodge Ram 2500 with the 5.7 Hemi and a 5 speed standard trans. Lately, he hasnt had the issue as much, but sometimes when hed start it, it would crank over like normal but then die. So you would have to turn the key off then back on and it would fire right up. Its kind of a hard thing to describe lol but I was just curious as to what could be causing this and if anyone else has had this problem.
05singlecabHEMI
Lilburn,GA
I kinda have the problem. When i first start it when its hot out i have to give it a little rev. Only when its hot. When i dont as soon as i stop itll stall on me. Never stalls when moving or as soon as i crank it. Never stalls when i give it a rev though.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Do you have any background on the truck like last TB cleaning? Thats the first and easiest thing to check, also these trucks will do funny things if the batterys on its way out.
BKNBK
MT. Vernon, IL
I'd say clean the Throttle Body. Might fix it, might not. But still a good maintenance item.
K
ktm1217
White Mills, PA
5.2L 318ci Magnum
Actually, he did have the battery replaced when it was at the dealer toward the beginning of the year..It actually hasnt really done it much in a while so maybe thats what it was. I cant really tell you the last time it did it since then..
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The computers in these trucks are the most demanding things and any drop or change in power cause them to act like a 2 year old on alot of sugar.
suzukiquadrider
cummins 5.9, 6.6 duramax
fuel regulator on my 2002 ram it would take 2 key turns to start and i got it replaced now it starts first turn.
dth418
Pittsburgh PA
had this problem last year, changed the battery and egr valve, runs fine now
K
ktm1217
White Mills, PA
5.2L 318ci Magnum
well well see if it starts doin it again but it seems since the battery was replaced it doesnt do it nearly as often. if it does do it, might change the egr and see what happens..
pavester
texas
egr is maybe a 40 buck part and 15 minutes of work. wont hurt to go to autozone and replace it, hell mine at 86k miles looked almost completely clogged. should really help
04Hemi69
Hey guys and gals.. Have a 04 5.7. Headin' down the road truck running great @60 mph. Outta the blue truck shut down. Have all the power...turns over but hasn't started since. New EGR ...cleaned tube with brake cleaner. New battery cause i killed the other trying to start her up. Any other ideas.. Fuel pump?
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
Bouncing of the walls, and climbing to the rafters. I have a lot of experience with 2 year olds and too much sugar.
:ryu-cvs-hadoken-a:
