Hitch extension
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Bent my pan the other week hooking up to the trailer. Went to retrieve my mower today after installing an eight inch extension. Worked great and honestly a lot easier to hook up. Put new shorter Gorilla nuts on the other day. Still haven't repaired the pan. Maybe next week...
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
That's Good plus it gets the Trailer tongue back away farther from corners of truck in turns
JPT
NY
2015 Big Horn
Are you concerned about the added leverage? You are putting more tongue weight on the hitch because of the added length (not saying it is more than it is rated for, just wanted to make sure you are checking and being safe).
Redtruck-VA
Redtruck-VA
Virginia
With the hidden hitch recessed so much it really does need to be extended to work right.
Lowrider357
