holly preformance intakes
jbmobbs
murfreesboro, tennessee
holly came out with these in may mopar blue finish bigger intake barrels, tighter throttle springs/response, bigger vacume line ports and uses all org sensors they are amazing incresed my mpgs about 2.5 or 3 all it cost is about 375.00 bucks lol its kinda paid for itself
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Pretty neat
jbmobbs
jbmobbs
its very nice lol they have them in new and refurbs are about 150 less lol most are in black tho i wanted blue to match my paint scheme on my dodge and had no choice but to get new but it was worth it big time lol
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
my bigger throttle body did not help my mpg's any. hurt the power in lower rpms also. but gave a real nice increase on the upper rpms.
and to bad u cant see much if any of that blue.
txbass06
NE Texas
5.9 Magnum
The color of the throttle body
Sent from my iPhone 4 using Tapatalk
jbmobbs
jbmobbs
o lol ill take care of that when i put the body lift on it cause ima put a throttlebody spacer on and a 12" round air filter on it so it will be seen lol and so i can get rid of that intake tube that leads into the fender
1999blkdakrt
Magnum 360
Curious if you have a link to these throttle bodies.
Is your 96 ram equipped with EGR, as you have a late 94/95 egr type throttle body and linkage. Never have seen a 96 with a 95 linkage. I have gone through hundreds of cores and have yet to see this.
Your pic of the throttle body shows no modifications to it, still has the throttle plate set screw cover up by the factory plug, I can still see the reduction to 47mm in the bores. Just curious if you have any pics prior to install.
jbmobbs
jbmobbs
i donot have an egr valve and i did have to modify the throttle cable for it to work no i donot have a link i went to nashville super speed shop and bought it right in the store im not a computer buyer ..... it dose have bigger bores in the intake chamber the vacume holes are slightly bigger and it incresed my mpgs and acceleration idk i just bought it and bolted it on.....i held the old and new side by side and i could tell the difference it dosent take a genuis to see the difference lol
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
and you know that the tb spacer is no advantage on our motors, dont you? its been dyno'd by a few and no hp gains shown.
