BlownGP
- Feb 10, 2013
- 6,082
- 1,572
- Location
- Houston/Baton Rouge
- 2018 RAM Harvest New Holland Blue
- 5.7
I knew you could do it!!!!!!!!!!!!! hahaah
I will even deliver it to you. I used to live in SD.If you would like something that looks 100xs better than that, I have an offer for you, that you can't turn down. Mostly because I feel bad that you went through all this trouble.
Ready?
I'll trade you my big horn hood for that terrible looking sport one.
IMO
I miss the 12 rolled tacos with guacamole from Robertos. Or the fish tacos at the Tilted Stick in OB.
Sent from my SM-G900V using Tapatalk
https://www.theretrofitsource.com/morimoto-x-drl-led-running-light-51963.html
Replacing my existing LED in my vents with these. They are a perfect fit height wise.
Still brainstorming on that.How do you plan to mount these? Aren't the openings in the hood slightly tilted upward? Thus making the light point up at an angle?
Those are LED bolts.Nice. How did you end up mounting them?
My earlier post of the Morimotos sat too angled and it distorted the lights. So i took them off.
The LED bolts screw in.
They are not even in this vent. I used my original vent and it was difficult drilling out the old leds.Ahh. So what bolt did you use and what would you change? I would like to do this.
Can you take a pic with them off and closer to the hood? I would like to see what they look like just sitting there.
Also, anything special you did with the wiring?
OK, let us know the size you land on.They are not even in this vent. I used my original vent and it was difficult drilling out the old leds.
These are a test run.
Only problem with the wiring is they are super thin.
EDIT: https://www.superbrightleds.com/moreinfo/led-wired-bolts/bolt-beam-12mm-led-light/1494/
You can find LED bolts here too. 12MM or even 5MM. I am thinking about going down in size. I just ordered a few different size to check them out.
This is what I just finished. The amber is my signal light.
