69mach1
- Joined
- Apr 11, 2016
- Posts
- 169
- Reaction score
- 28
- Ram Year
- 2013
- Engine
- Cummings 6.7
Greetings,
I've had the truck for a year now. ~ 3 months ago I swapped out the stock steering wheel for a heated leather wheel and all was well, horn worked fine and radio control buttons on the back of the wheel worked as advertised. Also when setting the alarm with the key fob the horn would chirp. Sometime after installing the 8.4 NAV (was a 5.0 factory) I think I was playing with the door lock settings and then sometime after that I noticed the horn button on the steering wheel didn't work, sometime after that I noticed the horn no longer chirped with the key fob when setting the alarm either. I've checked the 8.4 NAV and it is set to chirp the horn when setting the alarm, I also checked the horn fuse and it's fine. Seems like a BCM programming issue? Anybody else have this issue or have a fix?
