How can I get this out.
mpress2570
I peeled off the warning labels on my visors and it left a little adhesive behind. Anyone have the remedy to remove what's left behind?
mpress2570
mpress2570
oh man.. you just voided the warranty on your truck.
lol I've seen all those posts before it's a load of crap. I asked my dealer about those posts a while back.
07MegaCabRam
Chandler, Arizona
6.7L CTD
I would use a towel, put a good amount of ACETONE on it. Lay it up there, let it soak for about 15 seconds, use old tshirt or something LINTLESS and dap and wipe. Repeat as often as it takes.
whetrick1
Be careful the acetone might mess the color up also.
mpress2570
mpress2570
I used some goo gone let is soak in for a minute wiped with a cloth then scrubbed with soapy water and dried with a hair dryer and it seemed to work in the little spot I tested it on so I will try the rest of it later. Still open to ideas though. What kind of acetone should I use? Is there any that is colorless? Or will my gf nail polish remover work?
07MegaCabRam
Chandler, Arizona
6.7L CTD
That would work, it's not as potent as direct Acetone as I used in the past. If you can remove the sunvisor, it makes it easier.
mpress2570
mpress2570
Will nail polish remover work
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Take it off. Steam it and use a microfiber towel and smudge out the adhesive. Let it dry, rinse and repeat until done.
mdifilippo
NJ
Typically nail polish remover contains VERY small amounts of real acetone. Jack's suggestion above about steaming it is a great idea, it'll be the safest and cleanest way to remove the adhesive.
whetrick1
The WD-40 will work. Soak a rag and let it sit a min or 2 and wipe it off. Then clean the WD-40 off with some window cleaner or soap and water.
O.R.T.
Wessyyydddeee
O/P post a pic of the finished job. I'd like to see how well you got the sticky stuff off. :happy107:
ramportin1
Sickest member here
Oregon
im assuming this did not come off very great lol? real curious to know if you got it or not
Thunderbucket
2017 Limited
Brake clean on a rag.... lightly wipe it away
If you can't dodge it... RAM it!
Ftank
