How many miles to a tank you get?
Dtfanning
South Carolina
1999 Ram 1500 2wd
5.9L
1999 Ram, 5.9, AT, 2WD, and totally stock.
225 miles and she's running on fumes.
What's your Ram get per tank, typically?
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
my gauge says 18.6mpg and I've got a 26 gallon tank. should get just shy of 500 miles
CostaRam
Costa Rica
usually about 310 miles mixed driving.
Yesterday driving steady 60mph for 100 km i got almost 18 mph
Chris
kad
Hudson Valley, NY
5.7L HEMI
2014 1500 CC 5.7 Hemi, 26 gallon tank. Run 89 cotane and get about 400 miles per tank if I let it run down, but I try not to ever let in run below 1/4 tank.
-K
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
you're getting 8.5mpg, thats low unless you're in stop and go traffic. even then I get 12 no matter what i do under 55. at about 60-80 I get 14. I cant get above that no matter what I do (except go back to stock size tires and drive like a grandma, then I can get 16-17 highway).
First thing to do is check what that engine light is about. It might be nothing, but it might be something.
Since you have the 5.9, dont ever expect better than 12 combined. Usually 10 city and 14 highway is the best you can hope for.
Dtfanning
Dtfanning
South Carolina
1999 Ram 1500 2wd
5.9L
Its the low fuel light, not the check engine light you are seeing. Nothing is wrong with the truck, at least, its not throwing any codes. And I drive it easy. Not sure what the heck is going on with it. By comparison, I seem to be getting much worse mileage than most, unfortunately.
shadowhawk
Southeast WI
my tank is about half full right now and it says range 275 miles. If you believe the range estimator, that is
Max78
AZ
Magnum 5.9
98, 5.9, 4x4, 265/75/16 AT tires, 26 gallon tank, 320 miles till its on empty, mixed driving.
I get 220 miles from the fist "half" and about 100 miles out of the last "half" of the tank.
Check your plenum, check valve, and spark plugs. If you have no issues, check your cat, and muffler. I freed up my exhaust and saw a nice improvement in millage.
If all checks out new NTK o2 sensors.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
2WD should be getting closer to 16. You've got something wrong. lol
Check your plenum, plugs, and verify your trans is holding.
As for me, I get between 10 and 12 mpg as a rule. About 250mi to a tank.
dudeman2009
Magnum 360
I'm glad i'm not the only one with a ******** fuel gauge.
dapepper9
Iowa/Nebraska Border
5.9L V8
Regular driving i get 350ish. Highway i can break 400 pretty easy.
Scratch that, on my old tires that was true. Cant say yet on the new to me 315s
Joe w.
Virginia
318 5.2l
Between 335-400 depending on driving conditions
