From the manual:
"POWER INVERTER — IF EQUIPPED
A 115 Volt (150 Watts Maximum) outlet is located on the center stack of the instrument panel, to the right of the radio. This outlet can power cellular phones, electronics and other low power devices requiring power up to 150 Watts. Certain high-end video games, such as Playstation3 and XBox360 will exceed this power limit, as will most power tools.
The power inverter is designed with built-in overload protection. If the power rating of 150 Watts is exceeded, the power inverter will automatically shut down. Once the electrical device has been removed from the outlet the inverter should automatically reset. To turn on the power outlet, simply plug in the device.
The outlet automatically turns off when the device is unplugged.
NOTE: Due to built-in overload protection, the power inverter will shut down if the power rating is exceeded."
