How much brake fluid?
Jrod
USAF 1997-2008
Virginia
2016 Sport
I will be replacing my rear brakes soon and figured I should flush my fluid too. I've always had the dealer do it, but not this time. I've watched several how-to vids and ordered this power bleeder. My only question at the moment is, how much brake fluid do I need to flush all four calipers?
Jeepwalker
WI
2012 Reg Cab, 4x4
I was going to suggest 2x large containers of brake fluid. I guess my machine takes more to operate. Either way, you don't want to run short during the job, or if your pet tips one over on the ground during the process (or any number of other possibilities). Maybe get three small containers just in case. The power bleeder itself will hold some which won't get picked up. Return whatever you don't use. Personally that's what I would do. Typically a farm & barn place will have the best prices.
Just don't run it low. Otherwise you'll open up a new can of worms and extra work. It's easier than ya think bc new fluid should be clear as gin. Your power bleeder should make the process very smooth (smart move btw).
danielmid
Southeast WI
2015 Sport 4x4
It's a nice bleeder, I use the same one. I also recommend their little bleed bottle for the caliper side, super nice with a little hangar. Keeps everything nice and clean.
Jrod
Jrod
USAF 1997-2008
Virginia
2016 Sport
Thank for the responses! Something else I forgot to ask. I see you need to remove old brake fluid from the master cylinder with a turkey baster before you get started, but none of the how to vids I've seen say how much. Would it be to the low fill line or as much as you can get out?
danielmid
Southeast WI
2015 Sport 4x4
The more the better, get all you can out so you have less old to push through the lines.
Jrod
Jrod
USAF 1997-2008
Virginia
2016 Sport
Thanks! I also ran into this video just now. Essentially the same as you described.
MRFREEZE57
pacific northwest
Buy at least two 32oz containers of fluid and after flushing take the truck on a slick road and slam on the brakes a couple times to operate the ABS to circulate fresh fluid in the module.
Jrod
Jrod
USAF 1997-2008
Virginia
2016 Sport
:grd: LOL
chopperman1
2018 Rebel
5.7L HEMI
Don't use a turkey baster, it's too big, use your pump! Great pump by the way, have the same one. Get 2qty quarts of fluid. Drain and refill the master several times, pumping many times between changes. Once the master is clean then start on the calipers.
Shawn Burns
Lewisburg, PA
2016 Rebel
I extract as much fluid out of the resevoir as I can, then I begin the work replacing the pads. During that, you should be collapsing the piston into the caliper, which back feeds more fluid back into the resevoir from the lines. I then suck that out before I start the bleeding process. I use 1 large Pentonsin super DOT 4 to do all 4 corners.
https://www.amazon.com/Pentosin-1204116-Super-Brake-Fluid/dp/B007PCQCIU?th=1
I find it helpful to have one of these too, https://www.amazon.com/GreatNeck-QR...sh+button+quick+release+c+clamp,aps,87&sr=8-2 to compress the caliper
And one of these to hang the caliper...https://www.amazon.com/dp/B01LXOLITC/?coliid=I3EDCR7FEB1O9B&colid=2ASDOY1INH34T&ref_=lv_ov_lig_dp_it&th=1
