How to 1.5" Steel TGC rear coil spring spacer install
swh822
Great thread to follow while doing this...got mine done cleaned up tools and showered in about a hour 20 minutes ..2cf88be394dcded8a027b1a77147ddca.jpg32ae22ae6ef483b92df1f6408e73f5f5.jpg
Sent from my SM-G935V using Tapatalk
R.L.K.
R.L.K.
Bristol , Tn.
Great job Sir !
Love the color of your Ram .
Sent from my SM-G900V using Tapatalk
swh822
Great job Sir !
Ty for the color comment and Ty for these threads ..makes other people's jobs alot easier
R.L.K.
R.L.K.
Bristol , Tn.
Glad I can help ...
wtjoker
Should I go from .75 to 1.5 or just put airlift on it?
Sent from my SM-N910V using Tapatalk
R.L.K.
R.L.K.
Bristol , Tn.
Depends on what you're after ?
wtjoker
I like the stance now (with no load, maybe 1/4 inch or so more rake would be cool) but if I load something in the back I get the nose up more than I like!
R.L.K.
R.L.K.
Bristol , Tn.
If it's to reduce sag only while towing then air bags in addition to the 3/4" spacer may be your best option .
If you do not mind another 3/4 rake all the time , then go with the 1.5" spacers .
Remember , spacers do not fail , or require adjusting or any maintenance.
This is why I went with the 1.5" spacers.
wtjoker
garettmoore
Manitoba
Has anyone installed the 1.5" spacer on top of the 50% tuff truck coils?
crazykid1994
What rear shocks are people using with the 1.5" spacers. I've been told factory are ok.
R.L.K.
R.L.K.
Bristol , Tn.
49k and I'm still on my factory shocks in.the back & I have 1.5" TGC rear coil spring spacers installed.
The factory ones are fine for the 1.5" spacers . I.see lots of folks running the bilsteins in the back .
crazykid1994
Thank you. Good to know
R.L.K.
R.L.K.
Bristol , Tn.
Bump
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
@R.L.K. I stumbled on this thread doing research myself. Great write-up. I just had Fox 2.0 shocks added along with Bilstein 6112s up front on my Zone 6". I am tossing 37s on later, but until then I see I am 3/4 nose high and will put in a 1" TGC spacer. In looking at your DIY, you mention jacking at the diff then jackstands on the frame. Can you give me a suggestion of frame position for the jack stands? I have always just put jack stands on the axle in the rear.
Thanks!
R.L.K.
R.L.K.
Bristol , Tn.
Thanks!
I put jackstands on the frame just fwd of the axles , but you could put them anywhere near that location or more to the rear .
Hope this helps !
R.L.K.
R.L.K.
Bristol , Tn.
Thanks!
Here's some pics I just screenshoted and zoomed in a bit from my OP .
Hope this helps you Sir and thanks for the kind words [emoji1303]fc0e616d7a37d02ea611ce80a233072b.jpge2e60eff6192cf2504f836f0ab920999.jpge0f8c11cb0bcb936199df26d8489d6f4.jpg
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Perfect, thanks!!
R.L.K.
R.L.K.
Bristol , Tn.
great job super good commentary, i appreciate your work for us
Thanks man , means a lot [emoji1303]
I do like helping others when I can !
