Alright, I have a question about a cluster install.
So we know a 13 cluster is unique to 13 Ram's as far as the Tire Pressure Monitoring System ( TPMS ) goes .
My question is , are the TPMS Valve stem sensors unique to the 2013 Cluster ?
If this was the case then if a 14 + Ram was upgraded with a 13 premium cluster then you could replace your TPMS Valve stems with a set for a 13 Ram and the tire pressures would then show up on the 13 cluster as opposed to just _ _ dashes _ _ ?
Can anyone confirm this this would work .
Thanks for any response!
☆☆☆☆☆☆Edit ☆☆☆☆☆☆☆
I'm fairly certain this will not work , but I don't know for sure , Wishful thinking maybe .
I think maybe the 13 clusters tpms not working in a 14 + Ram is more likely due to a diff Bluetooth /RF module mounted elsewhere in the vehicle ?
Does anyone know if the clusters actually have their own Bluetooth module inside of it for tire pressure monitoring?
Thanks again for any response.
