- Nov 3, 2016
- 2,945
- 4,103
- Location
- The Palouse
- 2020 Limited
- Hemi 5.7L
Decarbonizing services I've seen advertised blast walnut shell (or other non-marring materials) to remove the build-up. This requires removing intake manifolds and quite a bit of labor. Which is why it costs so much. Using chemicals/solvents requires much less labor, and is generally much less effective. Of course, the end results depend on the amount of build-up that needs to be removed.I know of a person who had the decarbonizing process performed on their 3.5 Ecoboost at an independent shop and lost both turbos weeks later. If the decarbonizing method is using a chemical solvent injected into the intake stream, it could wash out a turbo bearing.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 100870 miles.
