Cbmhomepros
- Joined
- Aug 27, 2015
- Posts
- 4
- Reaction score
- 0
- Ram Year
- 2003
- Engine
- Magnum 4.7
OK looking for some help I'm dying here.
2003 1500 4.7
Put on rebuilt transmission
Month later starts shutting off. It shuts off like I turned the key off. All electrical stays on. Gauges freeze then a few seconds drop. I turn the key back to off then restart and it will start fine but still will stall but not every time. It will stall at idle, slowly accelerating, and if I punch the gas to say pass if it hits 4000 rpm it will squeal and shut off. It sometimes will shut off when slowly accelerating up a hill. Sometimes it will idle 15 min othertimes less than 1. Here is what I have done so far:
Replaces tps
Replaced iac
Replaced camshaft sensor
Replaced crankshaft sensor
Replaced map sensor
Replaced pcv
Replaced air filter
Checked transmission fluid
Checked battery
Checked fuel
Replaced ignition sensor
Checked fuel vapor canister
Newer alternator
Fuel pump seems to be working
Aamco said its code 83 wrong vin on pcm
I don't know how that could be
Any help thanks so much
2003 1500 4.7
Replaces tps
Replaced iac
Replaced map sensor
Replaced pcv
Replaced air filter
Checked battery
Checked fuel
Newer alternator
