84TSiGuy
Note Truck is a 2001 model. Also since his has 4 o2 sensors 2 pre and 2 post I'm fairly sure it's a California model.
So it's a wiring issue. I need to know the pin# on which plug of the PCM/ECU are the signal input from the pre-cat O2 sensors. I have a manual and it looks like on the wiring diagram it's pin 24 and 25 of the 3rd plug which is the closest to the firewall. The trucks not getting a signal from any of the O2 sensors, but I have checked the post and 1 of the pre cat sensors and they are generating a 0-1v signal when heated with a torch so they're not dead. So I'm lead to believe it's a wiring issue and rather than try to isolate the exact part of the harness that's the issue, and considering the post cat sensors as I understand it are just there for verifying the cats are working / emissions and not fuel adjustments the owner doesn't care (my friend) nor do I. But the pre cat sensors signal is important to making fuel adjustments so that we do care about and are just going to run a new signal wire from the harness O2 sensor plug to the ECU/PCM pin's.
Also which pin goes to which cyl bank? Also, note we're doing this because Dodge apparently doesn't have a single engine harness left in inventory, anywhere in the country.
