I think I need more fuel
bluethunder08
Whigham, GA
So I have the typical mods; headers, y, magnaflow, 180 thermo, and SC tuner. I was running a K&N drop in with Airaid MIT and it was pretty quick for a big ol' quad cab. Then I put on a S&B intake and a Moe's 87mm TB and she just fell on her face. Throttle response went to nothing and would really bog down at WOT. Put the factory TB back on and it pepped back up some. So now I'm thinking I'm not getting enough fuel for the air I'm moving. Is there any way to increase the fuel flow on a 2008?
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Given that the TB gives you (roughly for the math weenies) an 8.7percent increase in throttle diameter at WOT, you could be leaning out. I'm not familiar enough with the Super Chips tuner to know if there is any way to adjust your fuel air ratio.
I would start by calling Matt, or hoping he drops by this thread.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Did you do a PCM reset to aloow the computer to comp for the extra air your moving?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
I don't think you need more fuel as I even had ported heads with a bigger cam on my 03 with just Superchips.
I would start off by resetting your computer. If that does not work, try to run a higher octane fuel as you may be running lean now with all the airflow upgrades and getting some knock. If the engine detects knock, it will pull timing and cause a loss of power.
bluethunder08
bluethunder08
Whigham, GA
I only run 93 in it. I did the reset but will try again. I've realized that these trucks tend to have a mind of their own sometimes.
PCA4208
Albuquerque, New Mexico
It's funny.. I was going to suggest to reset computer as one of the first replies. But I thought I would sound stupid haha.
That's completely honest.. No BS
truckin151
2013 sport
you're installing the tb with all the right gaskets right? another thing, I wouldn't be adding fuel without logging the AFR, doing it blind is an accident waiting to happen.
