Im stumped. please help!!
Brevan
Ca
03 ram 2500 5.7 2wd
So I was headed to do a job and truck starts running real ******, out of nowhere. Dummy light is flashing, "ok got a misfire.. I'm not quite due for plugs and wires yet" bust out the scanner and its just 0300.. no cylinder is labeled nothing i.e. 0304, 0307 etc. Checked plugs, coil packs wires everything was good. Replaced crankshaft position sensor, ran perfect for 7.5 maybe 8 miles. Then it threw an upstream o2 sensor code. Replaced both o2 sensors. Now it's running way worse than first break down. Sounds kinda like the distributor is 180°off..
Any suggestions/ ideas
Thx a mil
HemiLonestar
MD
LOL....yes, you should totally check the distributor
Brevan
Brevan
Ca
Im fully aware it doesn't have a distributor, I was using that as a comparison to how rough it's running.. thx
HemiLonestar
MD
Run a compression test and see if one of the cylinders is off. If that doesn't give you a smoking gun, pop the valve covers, see if one (or more) of your valvesprings broke on you.
Brevan
Brevan
Ca
Thx buddy! I'll check those out and fingers crossed it ain't expensive
Martins hemi
Alabama
Mine done the same thing
03 1500 5.7 it was the intake gasket
Also check your valve springs
Hth
