Injectors ? Easy job or not
Discussion in 'VP44 Pump' started by ramhunter9, Sep 26, 2011.
  1. ramhunter9
    ramhunter9 Supporting Member
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P-Star Jeep Wrangler
    LOL , it is kinda
    I am going to do it , just worried about taking the fuel rails off and getting it all lined up with no leaks .
  2. Mopar1973Man
    Mopar1973Man Senior Member
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
    The whole trick is keeping everything clean and sealing problems should occur. So get a can of engine degreaser and wash the engine down good and trhen get working after it dries.
  3. KGBIGCOUNTRY
    KGBIGCOUNTRY Senior Member
    30
    13,314
    383
    MECH, VA
    Ram Year:
    2004 RCSB/2005 QCSB
    Engine:
    5.7 / 5.7
    How are the Ctds primed stock? With an aftermarket lift pump that would do the priming to get the injectors and pump fed but how it it done stock on these trucks? Also would he have to crack the lines to burp out the air or is that not serious enough of an issue to be done? when I have done injectors on equipment I know I have had to crack the main line for the pump then the feed lines for the injectors also.
  4. Mopar1973Man
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    Typically you crack 1,3,4 to bleed the lines out. Tighten them down and fire it up.
  5. dripley
    dripley Member
    75
    Aug 23, 2011
    hickory, nc
    Ram Year:
    2002 2500 ho 6 speed 4X4
    Engine:
    5.9 24v cummins
    wel dave i forgot you had this page. i just changed my injectors out last weekend and you are chicken chit if you dont do it your self. it is quite easy. you dont need a spark plug wrench they just pop out. i was surprised at how easy it was. you get her opened up and do #! and just repeat. mike has a good point on the cleaning though. i sprayed my down pretty heavy before i took a bolt out of anything.
  6. CumminsCrazed
    CumminsCrazed Senior Member
    32
    481
    35
    May 22, 2010
    North Central Iowa
    Ram Year:
    2001
    Engine:
    5.9 Cummins 24v
    obviously hes already done it as truck is sold but yeah, take VC off, take lines and X tubes out, use valve cover bolt to pop old injectors out, use same bolt to pop new in...i did all 6 of mine is about 45min to an hour. Hardest part was # 6 line, tube and injector popping back in.
Share This Page
