Interior Dimmer Switch Not Working
pdawg
2016 Ram Laramie. My interior dimming dial switch will not work. It will not turn lights off,make them dimmer, nor will it make them brighter (when moved to the right), nor will it turn on dome light if rotated all the way to the right. If I use the Uconnect 8.4Nav controls, I can go to manual and adjusted them through the touch screen. Just the dimmer dial switch seems turned off. It doesn't matter if heads lights are on, or if they are off.
Any thoughts?
P
pdawg
Solved - figuring it was computer related started trying different combinations of switch settings. Notice the driver air vent dial was all the way to the left position. Moved it to center. Dimmer switch working as normal now in all headlight settings. Bizarre!
OasisNinjaBat
