iNTERIOR LIGHT LENS
PaPitt
Stephenville TEXAS 76401
5.9L
So can someone tell me how to put a new bulb under the inside light up on the top center console .
... IF Memory serves me correctly It seems I've broken the little tabs off most of the last 2 or 3 I've made an attempt to remove . So before I break another .. I've got time nowadays . SO iT SEEMS A LITTLE FLAT SCREW DRIVER & PUSH IN . SOMEWHERE .
WHAT Do I Push on . I'm an old part man so I believe the bulb wil be a snap to remove .
... Thanks ..
Reactions: Mop
Mop
Yes, flat screwdriver on the outside end of the push lights. Just go easy on it, you don't have to pry too far before it pops out. Insert, pry lightly, pop.
P
PaPitt
5.9L
THANKS GUYS I ALWAYS FORGET ABOUT YOU-TUBE . & i'D HAVE WENT AFTER IT IN TOTAL REVERSE POSITION & i'D HAVE BROKEN IT FOR SURE .
thanks .
thoffmann517
