Introduction Need assistance with TBI to carb setup
MavMan
Iowa
5.2L 318
My name is Devin and I own a 1989 D100 RWD 5.2 L. It was leaking from all areas and I had the transmission rebuilt and I have been rebuilding the engine. I am now going through the carb setup and am running into problems with my wiring. I have read that the harness I have will not support carb set up and I need to find a different-year Dodge truck with the same block to firewall set up and non-TBI. I am now questioning the new distributor I purchased which was sourced to the year, I am guessing that was for TBI now and I need a different distributor. I am also assuming I will also have some alternator issues as well? I was hoping to find someone on here that has done this or knows how to do it in the most simple form. I have done all the work except machining the engine. It is a roller lifter engine with a cam that is just above stock. bored 0.030 over. I Have removed all of the smog features and put on long tube headers. Any assistance would be greatly appreciated.
Devin
Papa Red
Papa Red
Nebo, NC.
Welcome to the forum.
Post your question in the 2nd generation section and you will get some help.
Red
JustinRam1500
