Issues Starting
JamesA33
California
So im having a weird issue with my 2015 1500 3.6L. Once the truck has started its generally fine, but if the truck is off for longer than about 30 minutes to an hour when i get in to start the truck, ill turn the key over and it sounds like ALL of the battery is gone, like im trying to start a dead truck, lights fade out the whole 9, then ill turn the key off, and then turn it back to start and the truck fires up. Ive tried looking around for a while now and havent really seen anything unless im overlooking another thread, but does anyone know what would cause this issue, or has anyone else had a similar issue? Ive had the battery and alternator tested and both come back perfectly fine. Just looking for a possible cause or fix.
