So I went to look at this truck. Had been sitting on the lot since May. On a cold start, I did notice a small stutter when shifting but only when barely on the throttle. Truck would rev a tad higher than what one would expect, then the RPM would fall proportionate to the next gear, but instead of a smooth shift, would stutter or 'slip' or what seemed like it, 2-4 times quickly with a 100RPM or so jump before going into the next gear, it was minimal, and didn't happen every time in every gear. and never happened when the gear that it was attempting to go into was 2k rpm or higher, when driving hard, the truck performs flawlessly. Its only at less than 2k rpm that it happens. Truck has a lot of miles, but I got it for almost 10k under nada. so even if I end up replacing the trans, I'm still in the positive. Has any one had this issue? any solutions or attempts at one? I drove the truck almost 400 miles home. didn't seem to matter on a specific gear, or if the truck was operating temp or not. Only light throttle were a down shift would barely be necessary. But it is certainly concerning. I have not looked up the tutorials yet, but I intend to reset the throttle body, learned patterns of the trans and any other electronic memory function I can find to do for starters. Can anyone rule anything out for me? Torque converter? driveshaft? engine bogg? HELP!
