Richardson111508
- Oct 6, 2015
- 30
- 16
- 2015
- Ecodiesel
The Bilstein 5100 install was definitely a learning experience. It's a m!@#&$ to get the nut loose on top of the factory struts when removing them from the coil spring because there is not enough room for a wrench and you can't use a socket and hold backup at the same time.
I also had a problem reconnecting the sway bar link, which I have now seen at least three other people that had the same problem. The top threads on the link itself stripped out before getting tightened to spec (which is 30 ft lb from what I could find). Maybe that's too tight? Anyways, it cost me a two hour drive to find that part on a Sunday. I had 8 hours invested in the driver's side yesterday counting travel time, but I learned some valuable lessons that made the other side much faster.
This morning, I got started on the passenger side and was finished in 2 hours. Bils are set at 2.1". Went straight to the tire shop and got some Toyo Open Country MT's put on (295/60/R20). No rubbing whatsoever and it doesn't have the overstuffed look that 35's cause. Front end is being aligned right now. I'm happy with it, what do you guys think? The first pic is after the level, but before the Toyos.
