Key On Power Source 12V
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Hey guys, I'm going to be hardwiring up my dash cam is there any other fuse to tap into beside F93 Cigar lighter? The reason I ask is that I have already have my air bag by AirLift tap into that fuse is their another one or can I also tap into the same one? It's more of a in-line fuse setup though.
I have been going over and over which one or can I tap into the same one but anyway thanks.
Brandon-w
Yukon
2015 Ram 1500
U can probly tap in to the same one as your camera will be using less than one amp If it's like my camera.
Sent from my SM-G981W using Tapatalk
Bigdaddy
Bigdaddy
6.7L Diesel Cummins
Oh okay, I was hoping that I could, I have two 20amp add a fuse coming from F93 so I should be okay, thank you.
Brandon-w
Yukon
2015 Ram 1500
Just double check your camera specs make sure it isn't alot. I can't see your camera drawing much though so you should be good. [emoji106]
Bigdaddy
Bigdaddy
6.7L Diesel Cummins
Got it, thank you Brandon.
