Sig Schecter
I installed lasfit headlights and fog lights yesterday into my 2021 Big Horn. I went with them as it seems they are the go to bulb company on this site.
Two issues, one being the reason for this post and the second just being a little tip for others.
First off, the headlights (low beams). I ordered and installed the LAplusH11/8/9 bulbs. Same product for the fogs actually but after install they seem to be obnoxiously bright. I am certain I installed them vertically, with the actual led chips at the 3 and 9 o'clock positions. That is the correct orientation right? My headlights are now reflecting off street signs and mirrors of cars ahead of me. I changed my headlights over to led in my 2014 Ram and I do not remember them being this noticeably bright on objects in front of me. I did not have to adjust the position of the housing either.
Since a lot of people here use these, has anyone experienced this? Is there a fix? I hate the yellow factory halogens.
Second part I wanted to touch on was the fog light plugs. They are the H11 bulbs and the plugs do not quite match up to the factory plug. You can push the plugs together and they will turn on but there was no way to "snap" them into place like with the factory bulb and plug. The plugs from Lasfit have protruding nubs on either side of their plug. This little nub prevents getting a full seat on one side, and is shaped ever so slightly wrong on the other side which prevents snapping the little red tab back into place.
The solution is to first verify the correct orientation the new plug is going to go in the factory harness. Once you know which way it goes it should be fairly obvious which nub to keep and which to slice off. I cut off the nub on the "backside" of the new plug and slightly reshaped the nub on the front of the plug. Just hold up the H11 bulb you took out of the truck next to the lasfit plug and shape it to match. It will snap right into place.
