Leaking steel brake line
Discussion in '2nd Gen DIY' started by jackson4212, Jan 2, 2017.
  1. jackson4212
    jackson4212 Junior Member
    19
    Jan 2, 2017
    Ram Year:
    1998
    Engine:
    5.2
    I have a large leak in my front left steel brake like coming out of the Abs to the front right tire. I dont know what line to buy what fittings or what size in general. 98 5.2L Laramie
  2. crazzywolfie
    crazzywolfie Senior Member
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    i am pretty sure you would need 3/16" brake line and 3/8"-24 fittings to replace a steel brake line on one of these things.
  3. tactialmonkey
    tactialmonkey Junior Member
    20
    11
    Nov 7, 2016
    Ram Year:
    1996
    Engine:
    Cummins 12V 5.9L
    My 96 ctd had different size fittings on each end so watch for that but my same line leaked
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  4. crazzywolfie
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    i think it would depend on what line is leaking. there are a couple fittings that sometimes have to be re-used but i am pretty sure the one he is replacing shouldn't be anything special. usually the special fittings are on the master cylinder and the input on the proportioning valve.
  5. tactialmonkey
    20
    11
    Nov 7, 2016
    Ram Year:
    1996
    Engine:
    Cummins 12V 5.9L
    The output on the proportioning valve was a larger size than the hard to soft line to the actual caliper
  6. crazzywolfie
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    Well if he does have to re-use fittings all it takes is a 3/16" drill bit and a drill. I have done it many times on the fittingside that are not standard
  7. jackson4212
    19
    Jan 2, 2017
    Ram Year:
    1998
    Engine:
    5.2
    Are the fittings reusable? Can I get away with just getting a new line? Is there a method to bending the new line or can I get a tool to bend the new line and just have at it
  8. jackson4212
    19
    Jan 2, 2017
    Ram Year:
    1998
    Engine:
    5.2
    Also, do I put nylon tape or something on the threads of the fittings?
  9. crazzywolfie
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    i would personally recommend replacing any fittings that you can and only re-use what you must.
    no you don't need any nylon tape. the fitting clamps the line to the other side
  10. jackson4212
    19
    Jan 2, 2017
    Ram Year:
    1998
    Engine:
    5.2
    Can I bleed just that one line or would that bleed the master cylinder as well?
Share This Page
