LED Add on B/U lights
Plowman254
Want to add LED reverse lights to 2015 ram without a switch. Works great in acc mode, but not when truck is running. Any help would be great
Raist11
Canada
I would assume it's hooked up to an acc power line only or something.. go over your wiring and make sure it's wired in right.
P
Plowman254
First wired each on off each stock BU light, then tried tagging two to one stock light and lastly ran a hot line from the battery to a relay which works but the relay "Humms" constantly
ChivasSTR8
Grayson, GA
2020 Limited
I tapped from the 7 pin trailer harness for 2 additional back up LEDs. no problems on my 2015.
jadocs
Not sure what you mean above. You ran the hot from the battery to relay and used the reverse as a trigger? or are you saying you wired the LED directly to the BU and are using a relay? I'm not sure what your final setup is.
sbarron
Wasilla, Alaska
jadocs
Great write up sbarron.
