greychevy
Very nice man!
Thanks for the great idea.
I'm not familiar with these Strip lights.
The picture you show has the lights on the sides of the bed, not on the bulkhead. On Amazon, it's a once strip 16 feet long. Can you cut these and connect them with a wire or how did you bypass the bulkhead?
Thanks
Best check the ratings on the reed switches. Most I am finding are not rated for enough to handle led strips down both sides of the bed
Finally warmed up enough to install my bed lights, which are a necessity for anyone with a cover. The lights are installed under the bed rails and controlled by a magnetic reed switch on the tailgate. Lights turn on when the tailgate is opened and turn off when closed. I powered it by tapping the 7-pin trailer connector.
LEDs/Wiring under bed rails:
Reed switch placement:
Actuator magnet and reed switch:
Finished product. Can't tell from the crappy picture, but it gives you plenty of light:
Does anyone know how the cargo light switch works to add a switch in the bed? I believe the newer trucks are supposed to be coming out with a switch in the bed for that. Almost wonder if there is a way to copy or even use the new design?
