Led Interior door handles
Ram Man
FL
2013 Sport
Is it possible to add the illuminated interior door handles/door pockets to other trims?
I have the sport with led interior package as well as footwell lights so I am curious if I have the plugs behind the door and just need to replace a few door parts to have leds there?
Heres the thread that has gone no where
http://www.ramforum.com/f42/laramie_interior_handles-80544/
THANKS!
AllMoparParts.com
- Benny
Preferred Vendor
All
All
The door handle bezels are available but I believe the premium door panel shape may be different in that area. There is also the wiring factor, We do not know if the wiring exists or if this can be tapped off of something in the door.
I can provide any part numbers you wish but do not know if this retrofit is possible without a panel swap which can get very expensive.
-Benny
Ram Man
Ram Man
FL
2013 Sport
according to that thread, the laramie door handles and sports are identical in shape. Do you have a pn for the laramie door handle bezel?
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Here are the available part numbers for the bezels with LED
Left Black 1WD61DX9AC
Right Black 1WD60DX9AC
Left Brown 1WD61LU7AC
Right Brown 1WD60LU7AC
These are the same for the rear as well except they do not offer Brown in the rear for some reason, Perhaps that area of the panel is black on all of them.
-Benny
Ram Man
Ram Man
FL
2013 Sport
Thanks a ton Benny.
As for the lower section that is just a strip of leds that shines into the door pocket, is there a pn for just that part?
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Thanks a ton Benny.
No troubles,
I was not aware there were lower led's as well. When I check the catalog I see a door lamp part number 68203609AA which only applies to the premium door panels so I can assume these are the LED's. I cannot find any photos of what they look like though.
-Benny
Jerzey111
North New Jersey
-Benny
is it possible to just get the leds? i have the bezel but my led is missing. thanks
Charleston S.c
16 laramie
I ordered 5mm red led lights and was able to get everything running like factory in the door map lights,door handles and dome lights ,now I think I'm going to do the back light of the window controls on the led lights on door pockets it took 2 of these resistors on positive and negitive to stop the blinking but all good now , I also installed the puddle lights that show ram symbol in the void in the plastic of the door in all 4 doors instead of at the mirror, and factory they have the acrylic tubes for light and I went to a super bright led tube for the doors wires are just twisted until I sauder tonight98039499c766cdb943654803559f2df2.jpg0f42fc9dd804c7e494bd4fed81e9b12b.jpg2f5ceca8117b331317c914237b5c2eb0.jpg
Sent from my SM-G965U using Tapatalk
Charleston S.c
16 laramie
I also can find zero about if we can change dash cluster back lights as well dont really want to open the dash unless I know it can be done
Ram 17
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Can you find a part number for the wiring that’s connected to the led in the door handle bezel. I’m going to buy them and try it out. Also does the handle (1WD61DX9AC) come with the led or is that seperate?
The wiring appears to be part of the door harness. Send me your VIN and I will send you the part numbers to use if adding the LED accent lighting however please note the bodyside connector may not have the circuit present.
-Benny
chrisbh17
Did anyone confirm if the led bezels fit panels other than limited?
I have a big horn I'd like to do this to.. Can handle the wiring but if the bezels won't fit I wouldn't bother.
Thanks.
Sent from my Nexus 6P using Tapatalk
Luis Mendoza
Yakima, WA
How do you guys change your lights on the door handles to a different color? or is that not possible to do?
I have a 2014 Ram 1500 Limited
