LED interior lights
Samsonlabs
2014 Express Black
Anyone know exactly which lights in the interior HAVE to be canbus LED lights? Or which trucks/ styles have the canbus system? Or if you can have both through out? I talked with the tech guy at superbrightleds and he said easiest way to tell if your truck has a canbus sustem is unplug the light, start the truck with the light on and see if you get an error. I did that with the dome and the little push button map light bulbs out (door open) and I didnt get an error. I called the dealer service dept to ask but I might as well asked a quantum physics question as much good as it did me. You would think that they could tell you. I figure lights like the tails, reverse, and headlights would have to be canbus. The tech guy at SBleds said he wouldnt run a canbus light in a non canbus application. Anyone like to weigh in? I have searched through post after post but I never did find a for sure answer....
Galion
Edmonton, AB
All my lights are canbus in mine, no problems with them.
Samsonlabs
Samsonlabs
2014 Express Black
got my leds in from superbright today...map and cargo non canbus working fine...maplights had a small amount of flicker when they dim and the cargo I had to twist a bit in its cradle before it came on, but other than that they are doing good. No error messages on EVIC
maps: WLED-xHP5 (194 LED Bulb - 5 SMD LED Wide Angle Wedge Base)
dome: 4410-x9 (578 9 LED festoon)
Alfonsio
2010 Big Horn Quad Cab 4x4
Map Lights
Just a quick question. How the heck do you remove the original map lights?
I have tried and tried and then I tried the rubber band method and no go.
Thanks,
evanblain
Alberta, Canada
Thanks,
Wrap a piece of tape around it and leave a little tail where the two ends of tape come together and pull on that.
BlackRambo
Canton, Georgia
Heucobob
Are the map light bulbs the same as the license plate bulbs ?
Heucobob
Ok that’s what I thought . I want to order from super bright led and I want to make sure I order right . I want to do all the interior and the reverse and license plate bulbs .
Heucobob
Ok if I’m correct the reverse are 921
The dome is 4410
The license plate is 194 and the map lights and under the dash at the feet are Also 194 . Is this correct.
BlackRambo
Canton, Georgia
Found this sticky info in the DIY section:
4th Gen LEDs
Reverse - 921
Cargo Lights/Top mount break light - 921
Map lights - 921
Dome light - 4410
License plate - 194
Tail lights / Brake lights- 3157
Front turn signal / Side marker - 3157
Sonnyde
Long Island, NY
HEMI 6.4
Thanks everyone let's recap: I got a 2016 RAM 2500 HEMI 6.4:
*Dome light 4410 (canbus or non canbus?)
*map lights 921- same question canbus or not?
*under dash also 921
is this correct? if yes then I just need to know canbus or not?
thanks again!
im_deaf
Canada
5.7 V8
I've been trying to find an answer to that question. I have a 2017 quadcab st, changed out my interior lights maps/dome, cargo, reverse and plates. No flickering but did notice once in a while my interior lights don't come on when I unlock/open the door all the time. Is the 09-18 suppose to have canbus LEDs?
BTW only had the truck for 2 weeks, still learning dodge from gm
Wahrsuul
Central S.C.
From what I've read, the 09-12 don't have the same issues with interior LEDs as the 13-18. I swapped mine out with cheap Amazon LEDs with no issues.
im_deaf
Canada
5.7 V8
I could just have a faulty led, I'll double check that. Thanks
