LED tail light bulbs
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
So can someone correct me if I'm wrong but I just put superbrightleds LED lights in all my tail lights and everything works but I have the bulb out message for my left and right turn signal. From what I read I need to put a resistor with the bulb so it reads correctly? If so should I just buy the resistors from superbrightleds or is there another better option? All the bulbs are CANBUS.
lonestar21
CA
2019 Ram 1500 Big Horn
Just buy led tail lights on eBay
Rzrman328
The treeline
Bought my resistors on Amazon.
There's mixed feelings on using resistors.
I had bulb out messages too...the resistors fixed it right up.
1SilverBullet2
1SilverBullet2
North Dakota
I'd buy LED taillights but I'm already at the edge of my budget so thanks for the suggestion.
Rzrman-I'll order the resistors then and give them a shot, if they don't work I'll look deeper into it. Thanks for the response.
Rzrman328
The treeline
Just remember to tap into the turn circuit and not the tail circuit. :happy107:
1SilverBullet2
1SilverBullet2
North Dakota
Haha yep. Do you have pictures of when you did them and which wires you did?
Also now my left license plate light is nearly out, it's super dim( it's led too). Is that from the tail light LED's? My right plate light is just fine.
BlownGP
Houston/Baton Rouge
Could be a bad LED or try twisting it 180*
And yes you need the resistors, I can't remember the wire colors. I think the turn signal wire is actually different colors for each side. Just tap them until they blink normal and the bulb out message goes off.
1SilverBullet2
1SilverBullet2
North Dakota
Alright I'll just check power for the wires then. And I've had those plate lights for quite awhile now. I'll try turning it and see what happens.
