Lift question maxtrac plus level
gray8188
tampa, fl
I have a 2010 dodge ram 2wd I bought your 4.5in front lift and 3in rear kit. I'm about to install it in my truck. I currently have a 2in fat bobs spring spacer on the truck. Can I leave the spacer on when I install the spindle lift to give myself 6.5 in of lift in the front?
Maxtrac Suspension
Anaheim, CA
4.7L V8
yes you can but please keep in mind with 6.5" up front and 3" in the rear you may be sitting rear low. We offer a 1.5" rear coil spacer you can add to the rear though its part# 1628 you can always order it later if you feel you want to add it. Thanks for your support
G
gray8188
tampa, fl
Okay thanks just wasn't sure if it would throw something out of spec. Can I still use the stock struts up front?
G
gray8188
tampa, fl
And if I need to upgrade the front shocks how much for the bilsteins? That's what I have for the rear just don't have the fronts.
Maxtrac Suspension
Anaheim, CA
4.7L V8
We recommend you run our slightly longer front shocks. We have either the Maxtrac brand or the Bilsteins. As for pricing and purchasing any products you will need to contact a Maxtrac dealer because we do not sell retail direct. Do you already have someone that you have been working with for the other products?
G
gray8188
tampa, fl
Hey sorry took so long to respond. I do not I bought the kit from someone local. Do you have a part number for the front shocks I would need to run the spindle and the spacer?
Maxtrac Suspension
Anaheim, CA
4.7L V8
The Maxtrac brand front shock part# 1450SL-6 or Bilstein part# 762115 and they are sold individual so be sure to order two. Thanks
OasisNinjaBat
