Looking for gear chart
Discussion in 'General Discussions' started by RompinRam, Feb 22, 2012.
  1. RompinRam
    RompinRam Senior Member
    1,501
    98
    Oct 24, 2011
    Hoffman Estates, IL
    Ram Year:
    2003
    Engine:
    4.7 Magnum
    Hey guys, a while back I had seen a chart on here that showed what your best RPM's would be with like tire size and gear size I believe. Does anybody know what I am talking about. If so I'd appreciate some help trying to locate it again.
    Thanks all!
    I am here: http://maps.google.com/maps?ll=41.778080,-87.866399
  2. txbass06
    txbass06 Supporting Member
    29
    4,129
    48
    Oct 27, 2010
    NE Texas
    Ram Year:
    1996
    Engine:
    5.9 Magnum
    This it?
    [​IMG]
  3. RompinRam
    1,501
    98
    Oct 24, 2011
    Hoffman Estates, IL
    Ram Year:
    2003
    Engine:
    4.7 Magnum
  4. RompinRam
    1,501
    98
    Oct 24, 2011
    Hoffman Estates, IL
    Ram Year:
    2003
    Engine:
    4.7 Magnum
  5. Trupiano
    Trupiano Registered User
    33
    10,982
    667
    Jun 27, 2010
    Hometown : Puyallup,WA Stationed : Little Rock,
    Ram Year:
    2010 Ram 2500 6.7L CTD Crew Cab
    Engine:
    6.7L CTD
    Yellow is more efficiency, black is OEM, blue is more power.
    Tapatalk'in
  6. RompinRam
    1,501
    98
    Oct 24, 2011
    Hoffman Estates, IL
    Ram Year:
    2003
    Engine:
    4.7 Magnum
  7. glass3222
    glass3222 Senior Member
    37
    2,340
    Jul 2, 2010
    Central PA
    Ram Year:
    2005
    Engine:
    No you will not be more efficient. One thing to remember with that chart is that the RPMs are with a trans gear ratio of 1:1(no overdrive) at 60 MPH. Your Ram has a 0.67:1 second overdrive, so the RPM in the chart will be much lower than that. You will be more efficient with a 31" tire and 3.92 or 33/35" tire with 4.56 IMO
  8. Ramunit
    Ramunit Senior Member
    816
    129
    Jun 30, 2010
    Ram Year:
    2005
    Engine:
    You must multiply those RPM numbers by .67 to get the accurate RPM if you are in 5th gear.
    OR..... If you want to do the formula yourself it's:
    mph x gear ratio x 336
    _____________________
    Tire diameter
    x
    trans gear ratio
    70(mph) X 4.56 x 336 = 107251.2
    107251.2 / 33(tire dia) = 3250.03
    3250.03 x .67(5th trans ratio) = 2177.52
    2177.52 RPMs at 70 mph in 5th
  9. RompinRam
    1,501
    98
    Oct 24, 2011
    Hoffman Estates, IL
    Ram Year:
    2003
    Engine:
    4.7 Magnum
  10. Trupiano
    33
    10,982
    667
    Jun 27, 2010
    Ram Year:
    Engine:
    6.7L CTD
    Tpellus, what's with the "I am here:" google maps link?
Share This Page
