Lost some coolant, would like some advice please.
Moparoadrunner
USA
Couple of days ago i had a leak from the top radiator hose - loose clamp, in the overflow tank the coolant wend down just under the low cold fill line when hot. Coolant temp was normal.
Next morning added coolant and put cap back on before starting engine, drove around , no leaks, coolant temp normal.
only thing i noticed the coolant does seem to rise up in the overflow tank a bit higher then usual when hot, but i remember it doing that on some days before anyway, maybe it depends on barometric pressure
Then i thought about what if there is air in the system, do i need to bleed it?
Now i am asking about it here if i should be worried or leave it alone and not fix what's not broken?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
When you engine is cold, not running
Look at the water pump
in the upper left, do you see a Plug ? That is a AIR BLEED Plug
as you fill the radiator, the coolant will run out & you can see when the air is no longer there.
Squeeze the hose a couple times when filling
If someone has rounded off that plug & made it worthless ..
Look over to the right of the water pump, there is a sensor
If you work carefully, you can remove that sensor & whatever screws into the water pump.
Fill the radiator watch for air in the coolant
Use the sealant paste, not Tape, on the threads
after about a you might look at the system for Air again
Moparoadrunner
Moparoadrunner
USA
I read about the bleed plug on the water pump but they only mention it when you are filling the coolant overflow when it is empty. does it work for bleeding after the overflow tank has already been filled? thee hoses have metal springs inside, they can not be squeezed. If the heat works fine and temperature stays normal can air still be there? Do normal drive cycles eventually expel the air anyway?
Daw14
If the temps appear normal to you stop here.
OasisNinjaBat
