Lowered 4th Gen Pics - Show Em Off!
Speedy720
Less is More!
2 in in rear..
Trapinator
Houston
Finally got the rear buttoned up. Relocation brackets from illicit customs (no cut kit) re centered the wheels, corrected the pinion angle. Also installed air lift helper bags and the hellwig sway bar. Very impressed after only one night of driving. Rides and Hooks like a dream. Looks like going another inch or so in the rear won't be an issue now!06bcc2b904b734bd20b3528284892d53.jpg29525b6172803388600bbae3987df9ac.jpg48231011fbca145db26d1c443277918f.jpg966e362961873d816e3395083f3b3b36.jpg64bd7b83c8ffb41754d6ae19df6ca5a6.jpg05c54d9da301ece377b84d80c5879213.jpg1552a5ac66d8fc5681ddb31798f9191a.jpg
Gary's Hemi
Walker, La
How did the install go on the Illicit brackets? Was it easy?
Gary's Hemi
Walker, La
Wasn't too bad. Main thing is getting lined up and drilling the new holes.
Could you get the drill in there & drill the holes straight or was it tight to work in there
Trapinator
Houston
Yessir, did take some muscle. Itd be nice to have a lift lol overall wasn't too bad didn't need to disconecct the brakes either. Me and a buddy knocked it out in a few hours
Gary's Hemi
Walker, La
Yea I have seen pictures where people have pulled the whole rearend out of the truck to install the brackets. I really want & need them to get rid of the high speed sway, just need to break down & buy a set
Trapinator
Houston
That's the true test for me too. I got the wobble at 120 or so depending on the road. We will see soon and update
Speedy720
Magaughys 2 inch springs. I didnt want to go any lower. The 22 s look ok but the plan is 24" hellcat replicas. Giovanna has a sick ass wheel also that looks pretty close to the hellcat wheel in black.
rtorres51
Lubbock, Texas
My 2015 Black Ram Express lowered with Inez Hotrods 4/6 kit. Very pleased with ride. Tires are 275/55/20, Falkens. Rear bump stops are removed. Haven't bottomed out yet. Drives normal. Tie rods shaved off, alignment back to factory settings. Left the rear Beltech shocks on and running factory shocks up front. I bought Airlift helper bags just in case, but looks like I may not need them installed. With this kit, the tire setup, I just only have 1/2 of an inch between the side wall of tire to the edge of upper control arm. You can run wider tire, but as you know, tires flex. That was a surprise I was not expecting. Overall I'm very pleased with the kit.
private_trips
El Paso, TX
My truck.
Here's my truck, 2014 Bighorn, debadged and 2/4" Mcgaughy kit. I have a really bad "bottoming out" problem in the rear. Should I remove the bump stops or get new rear shocks. Suggestions???!!!!?!?
1qikdsl
Are you still running factory bumps in the rear? If so I would either trim them a little shorter or run a shorter aftermarket bump stop. I wouldn't recommend removing them all together. Hitting bump stop is annoying but hitting metal to metal would be much worse
Garage9400
FL
Hemi 5.7L V8
2016 Ram 1500 Express RCSB
New to the site
My 2016 Ram 1500 RCSB
5.7L Hemi Stock for now
Mufflex Agressive Magnaflow Exhaust
2/4 Belltech Lowering kit
Hellwig Swaybars Front & Rear
22" Hurst Stunner Wheels
Factory Ram Projector Headlights w/ HID
Custom Diamond Stitched Leather seats
Upgraded Sound system
update: 8/29/17
added
Vararam Intake
Moe's Performance 87mm Throttle Body
Diablosport Trinity Tuner
Billet Catch Can
tones2SS
MA
New to the site
Very nice!
Welcome to the site.
Ohninehemisport
Chicago
Here's my mine with 24" RT 's, belltech 963sp, Illicit no cut, Inez upper arm, ford links and airlift rear bags
picture.php
picture.php
picture.php
Trapinator
Houston
picture.php
picture.php
picture.php
Good looking truck man. Digging the 4s
We're the inez uppers to correct the alignment, I believe somebody just posted about it few days ago. I have same setup minus the inez CA98d53e3cba29b198d44486983aa346ef.jpg
Ohninehemisport
Chicago
Yes, after installing them 3/8" longer than stockers and after alignment, the camber cam bolts on the lower control arms are somewhere in the middle. Before they were nearly maxed out. Definitely gives more headroom to align. And the ball joint angle is far better than the stock arm.
