LT E tires from factory PSI
BuschLatte420
chill water by day, drink beer by night
WNY
2022 classic tradesmen crew cab 6’4 box
5.7L NON E-TORQUE 3.92 gears 4x4
Just seeing if anyone here had a ram 1500 come from the factory with a E rated tire ( was a build option) and if so what the PSI recommendation is on the door jam sticker. Thanks!
PaleFlyer
Charlotte NC
My '18 rebel came with AT2's, not sure off hand the rating, but it's 55 front, and 45 back. But like nlambert said, they likely don't "re-rate" the tire pressure for alternative tire styles.
BuschLatte420
BuschLatte420
WNY
The door sticker will still show the same psi rating as a non load range E tire. I believe it's 44 psi cold.
My truck that came with P rated tires 265/70r17s said 40 front and back.
BuschLatte420
BuschLatte420
WNY
When I purchased my ko2’s bf Goodrich said to put 47 all around so I am rocking that currently. Truck is going to dealer for a few things including a steering issue so don’t want them blaming my tires that are still stock size but E rated and a higher tire pressure.
PaleFlyer
Charlotte NC
Dealer will probably just drop the PSI. Especially this time of year, tire PSI can swing 5+ PSI. I adjust my tires 2-3 times a year (avg), and check with the TPMS in the truck, and I have seen it start at 50/40, and by end of day driving around doing ****, plus the temp swings we get here, they can be almost 60/50.
nlambert182
Huntsville, AL
I would just set it to what the sticker on the door says if you're concerned with what the dealer might say. But.... 47 psi isn't really a big deal. Now, if you had 80psi in there, that might be a different story.
BuschLatte420
BuschLatte420
WNY
If they fix my issue they can do whatever they want I can just fill them back up. Steering wheel has always been a hair to the left but truck drives and tracks good, but now in some left turns seems like the eps or something forces my truck to stay in the turn and I really have to manually correct it. Or like the eps moves the wheel when I put no input in to. Not good.
indept
South Jersey
Don't guess, do the chalk test. Go to YouTube and search "Tire Chalk Test". That will set your tires at the correct pressure.
